Locking grease coupler
Good to see you back on!!
No but they look extremely handy for loose grease fittings. .. I’m guessing the lock onto the grease fitting like an air hose coupling?
Very cool….
Description
An incredible new design that locks on the fitting with just a slight push and releases with same minimal effort. Easy lock on and release. Does not drip, no matter the pressure, grease won’t leak out the sides. No need to hold the grease gun with knees while trying to hold the coupler on the fitting as grease is pumped. Small design allows for navigation into tighter areas than other lock on couplers. Fits most grease guns and accessories. Specifications: • Item: Grease Coupler • Brand: Univer-Co • Material: Steep • Connection: 1/8″ NPT Thread • Unit of Measure: EA • Max Pressure: 10000 PSI • Features: Locking • For Use With: Grease Gun
Yeah that’s how the demo display at the case dealership worked
Lol this “WILL CHANGE YOUR LIFE” it says
Glad to see you back. Jump right in where you left off showing us this great product looks like a real game changer.
FazzmanMember since Apr 2014
I havent used one,but judging by the terrible reviews and the cost,not sure i would.  Good in theory. Maybe if it were made by lincoln lubrication or something.
The coupler on mine is adjustable and you can get it to grab any zerk fitting. I could see a locking one being nice for certain applications then some clueless guy uses it and forgets to unlock it off the zerk and destroys stuff.
Yeah $40 is a bit steep for the bad reviews. It’d be nice in theory, I wish Waukee or Walt would start putting reliable ones of these on their guns.
