I have read about plier wrenchs from you guys so when Menards had their 11% off sale I took a trip there to get one of the Kipnex Plier wrenches. While checking them out I could not see any advantage to using a Crescent wrench. What am I missing?
They are quicker than using an adjustable wrench and IMO you can grip much tighter
The jaws close and open parallel,they are also faster.
I have the smaller one on my wishlist,I havent really been buying too many tools lately other than things I need for around the house maintenance wise and such.
Personally I hate adjustable wrneches
Their quality is pretty fantastic off the bat. The parallel closing jaws grip really well and limit marring surfaces. You can use them like a ratchet by alternately loosening your grip. They can flatten small sheet metal pieces, kinda like a mini metal brake. I use them to fix dented putty knife edges. They are just useful all around. I have a pouch for my must have tools that has a ratcheting screwdriver and my Pliers Wrench in it at all times. It can replace a bunch of other tools and excels at most jobs, unlike many jack of all trades…
I own 3 sizes. They are great, require very little pressure to grip nut very tightly. Adjustable wrenches require constant adjusting to keep them tight on the nut, then loose enough to slide on again. Plus they tend to slip and round off nuts. Try one. You will never go back to adjustable, and rarely reach for an open end.
JerryNY wrote:
8 minutes ago, JerryNY said:Their quality is pretty fantastic off the bat. The parallel closing jaws grip really well and limit marring surfaces. You can use them like a ratchet by alternately loosening your grip. They can flatten small sheet metal pieces, kinda like a mini metal brake. I use them to fix dented putty knife edges. They are just useful all around. I have a pouch for my must have tools that has a ratcheting screwdriver and my Pliers Wrench in it at all times. It can replace a bunch of other tools and excels at most jobs, unlike many jack of all trades…
The ability to ratchet is a plus, something I didn’t think of. They seem like they would be bulky. I mean not be able to get a grip on nuts, in some tight spaces, due to the size of the jaws. I rarely use a Crescent wrench because of their jaw size and thought the Pliers wrench would be just as bulky. I usually use my ratcheting Gearwrenchs but some times have to go back and grab another one because I misjudged the size. If the Pliers wrench ratchet pretty easily I might try out a pair.
Fazzman wrote:
1 hour ago, Fazzman said:The jaws close and open parallel,they are also faster.
So you have the larger one?
If so, is it too large and the smaller one would be more usefull?
When I was looking at them I was not sure what size to get.
The 7″ plier wrenches can get in some pretty tight apots
They definitely grip significantly tighter and are significantly quicker to use. It pretty much solves all the annoyances of an adjustable wrench.
I’m a huge fan of the pliers wrench and the cobras. Other Knipex tools are nice but those 2 are game changers.
2 minutes ago, DR99 said:I’m a huge fan of the pliers wrench and the cobras. Other Knipex tools are nice but those 2 are game changers.
I think you can add their diagonal, mini bolt and wire cutters to that list.
Those cobolt mini’s are sweet. You can cut a penny in half like nothing.
And the cable shears
Well I’m sold
Check it out,
http://bethepro.com/forums/topic/btp-review-knipex-pliers-wrench/
Plier wrenches are great for field work where you need to expect the unexpected. For fittings and fasteners that I know sizes in advance, I prefer a ratchet flare wrench, box end or socket where I can grab the fastener at all 6-points. Great for snugging up AC line sets to mimimize chance of leaks. Fast action open end wrenches are also pretty handy. SD
I bought the 10″ set on a whim and was amazed at how well they grip and leave no marks. Bought the 7″ set and haven’t used an adjustable wrench since. The 12″er’s are a bit pricey but on my list.
The 12″ are great! Most one I grab though is the 10 they fit just about everything
wife bought me the pliers wrench for me for valentines day (heavily suggested) and love them. had cobras before as well and use them both routinely. I need to get the 7″ or smaller versions of both for the smaller spaces.
But you need torque wrench for that, if you’re talking about flare fittings. Would work as the backup wrench
8 hours ago, KnarlyCarl said:But you need torque wrench for that, if you’re talking about flare fittings. Would work as the backup wrench
I’ve never seen an HVAC contractor torque a flare fitting and I’ve never seen any torque specs from AC manufacturers.[External image (www.ultimategarage.com), not copied][External image (www.ultimategarage.com), not copied][External image (www.ultimategarage.com), not copied]
