High grit count ROS sheets
Normally I can’t find anything over 220 5inch discs for my ROS. I found Nortan 320 grit discs at Menards today, not sure if anyone else has been in the same boat I have.
DaveJr.Member since Nov 2015
I only buy Diablo discs and have never seen anything over 220, not that I really need anything higher.
That’s that’s usually the highest I ever can find but I like to go higher on certain things I have to switch to the palm sander, which isn’t bad but nice to be able to just switch a disc.
khariVMember since Dec 2014
You can usually find 320’s at Lowes too.
Never found them higher than 220 at my lowes
400 grit at local lumber yard for 5″ pressure pads, what does yours take? Hook n loop?
Yea hook and loop
