What kind of chisels should I get?
RutterMember since Apr 2016
I am looking to get a new set of chisels because one of my cheap chisels has disappeared. What kind of Chisels should i get? Keep in mind I don’t want to spend to much money.
Are you talking wood chisels?
Stanley baileys are nice but pricey… The fat max or more for contractor work where the baileys are finer wood working
hemdaleMember since Sep 2015
My 2 cents:
– Pfeil chisels are very good and rather easy to sharpen. I’m not a huge fan of their handles though.
– Veritas Butt chisels ( PM-V11 steel): pricey but not crazy pricey. Edge retention is stunning. Excellent quality value. Amazing wood handles.
In a more “contractor” environment: the latest Hultafors chisels are built like a tank, razor sharp but probably not for delicate work.
Hope this helps
Just go with a cheap set if you know how to sharpen stuff. Like with a water stone or dimond stones. If not get the Stanley ones. Best for price for durable and sharpness out of the box.
Millerz
And the kolbalt chisel are good or I’ve used some olympia chisel for a long time too.
Millerz
MikeInCtownMember since Mar 2016
Need more info. What are you using them for, and how often do you use them? I have two sets of chisels. One has some heavy duty plastic handles that you can smack with a hammer and I use these at work for doing stuff on wooden doors like fitting hinges or latches. I also have a nice set of Two Cherries chisels that I would use for woodworking projects at home, but not actual home type projects.
Millerzconstruction wrote:
Millerz
I wish it were that simple.  There are really three things you pay for in a chisel, the handle, the grind, and the steel.  The third is really the only important part, and you can find cheap chisels with good steel, but there are some that are so bad they won’t take or hold an edge no matter what.
I’m sure someone here can recommend cheap chisels with good steel.
mohawkdecMember since Mar 2011
Rutter wrote:
jimbo gave you two excellent choices, i know this because i have both. the baileys are more money and come with a leather pouch, i use these only for real fine work. i use the fatmax [which are excellent for the money] to ‘rough’ in work when i need to really pound on the handle. they cost enough though to where you dont really want to abuse them too much. if you want a demo chisel, check out the dewalt, i have a set of these, they run around 10 bucks each, and i really abuse these
I have a Dewalt side struck chisel and the factory edge is so sharp I slit the side of my hand open when it was sitting there out of sight.
i know, i love mine, ive actually used a 3lb sledge when i had to chisel a joist or stud to make room for something.
If you know how to sharpen a chisel it don’t matter… And there isn’t that big of a difference in chisel. Unless you start buying 200 dollars pulse sets
Millerz
I always sharpen a new chisel straight out of the package. They are never as sharp as they can be from the factory. The normal chisel from the hardware stores any way. Never had the money for the high dollar ones. Lol. And I could probley get them sharper too. I shapen stuff on the side. And like a hobie I guess.
Millerz
Millerz
Except that damn Dewalt side strike! Chisel 3,Jimbos hand, bloody!
Is it the one that has the ridges on the blade part? I was looking at um the other day. Do you really like yours?
Millerz
Question
Millerz
Question
Millerz
Yea dude it’s a great durable chisel that you can really whale on and it still holds an edge. Having the side of the blade with an edge is awesome to have.
That’s the one! I think I’ll get it tomorrow if I have time.
Millerz
Millerz
Those dewalt one look very nice and solid I’ve wanted to jump on them but just never did.
I just have the 1″
redmedMember since Dec 2014
What do U use the side blade 4?
It’s a nice wide blade, if used it to knock stuff off of edges or even like a plane.
I could never own those. I hold chisels for detail work by the metal so  don’t take too much off and get the right angle. I’d slice my hand open on those things.
FWIW the cheap chisels I have are the blue handle Marples chisels which are apparently now Irwin/marples.
Check out the Bahco 2448 it’s rather a versatile chisel.
