New dremel multi tool. 7 Amp motor, so this is a powerhouse, but the bigger deal is a 5 degree swing on the blade. Not so good for fine details but this work much faster than any other OMT
[External image (mdm.boschwebservices.com), not copied]
http://www.dremel.com/en-us/TOOLS/PAGES/ToolDetail.aspx?pid=VC60-01#.Vv6-n_krKHs
The big question though is why is this using the standard Dremel blade change? Bosch owns both Dremel and Starlock, and the whole point of Starlock is to provide a stronger blade change for more powerful multitools. Not only that, but the Dremel blade lock is a smaller (ie. weaker) version of OIS. If you didn’t already think starlock was a money grab to drag out the incompatibility of multitool blades, this should be convincing.
Please convince me otherwise. I just can’t seem to find a valid reason no matter where I look.
Jeff I agree that to me is like hitting a line drive to left field you think your going to hit a home run and the left fielder jumps up and snatches an out… Great concept just falls short maybe they thought if they changed blade styles they’d piss Dremel users off.
I have to say I like the pin lock Milwaukee has even if it takes a few seconds to change it seems to be a stronger design I know I like that the M18 is toolless just the same…
