GearWrench 81209 3/8 Stubby ratchet 84-tooth $15
Nice find just ordered it can’t pass that up
I know, I don’t really need it but it’s a killer price. I also wanted to check out the 84 tooth mechanism, some prefer it to the 120XP.
KatoMember since Jan 2014
It’s, it’s, it’s sooo dinky, poor little thing. Well, maybe not as dinky as my Titan Micro…
What a deal!! I also order one too. Thanks BMack.
This one might be small in length but it has more girth! I knew a girl like that in college, she was known to give very good…
bet she didn’t use superlube
PermaTex??
Think it was grape jelly, girl was like 5′ even and like 2 bills.
T75RMember since Jan 2016
Lmao!
That’s a great deal might have to pick one up
Hmmmmm….. Self control is a bi**.
Whats that?
Whats that?
It’s an elusive concept, some day I have it figured out and some days it has given up and ran off, leaving me alone standing with an open wallet at the tool store like a fool. It seems to me that I only have self control visit me after buying a proto pipe wrench that I really can’t afford.
Received mine, definitely not even close to being as smooth as the 120XP but I’m sure some Superlube will improve this little guy. I mean who doesn’t perform better with a little lube?
Yea I might open mine up Monday to lube her up
Mine was bone dry too. Gonna take it part and compare it to my snap-on 80.
Mondo1310 wrote:
Please post comparison pics, I haven’t seen the inside on a Snap-on 80. I’ll post the inside of the 120XP with this stubby probably tomorrow.
I haven’t got the stubby yet but just opened up that s k and it was pretty dry as well.
That little thing was a pain in the butt to get that retaining clip back in. The Gearwrench uses real retaining rings.
Thought it was just me, although I figured it out faster than the fine tooth protos I got those are pretty interesting to take apart.
Finally got a chance to tare down the ratchet the line is pretty dirty inside check it out
A little bit of bare metal on the gear as well
Hard to get it focused… Superlube to he rescue!!
You go Jimbo. Probably a good idea to do that to mine as well.
Sent from my iPhone using Tapatalk[emoji41]
I’m not into vehicle mechanical, nor am I Conductor, a machinist, or an engineer, but a bare spot of metal doesn’t sound right.
Nice job looking into that jimbo, good thing you got this forum to advise you to tear it down and superlube it!
Interesting think is that it’s symmetrical wear on the gear, same spot on both “sides”
khariVMember since Dec 2014
Ok, so question then for the peanut gallery. I picked up the same wrench.  I’ve got a tube of SuperLube and pair of retaining ring pliers.  Is it worth opening up to lube?  How difficult is it to get back together again?  I know it’s not a major investment if things go south, but I don’t like to screw things up if I know something is just over my head to fix.
This one is pretty simple… If you want tomorrow I could do a video for you, once you remove the retaining ring carefully pull the drive out, with this one you’ll see the drive with the gear, there’s the pawl and a gasket. Be careful when you pull the pawl out not to jar the spring in the selector or you’ll have to put that together too. I wipe out all the existing lube, now I don’t use the grease I like the oil but I lube the whole thing with a nice coat especially the gears and pawl. Tricky part is just fitting the gear and the pawl back together but it only fits one way of the other depending on the way the selector is. These gear wrench have a O ring that goes in as well.
Basically what Jimbo said but I like synthetic grease, just a dab on the gear so you have lube where the gear rubs against the head. Then i put a little grease on the pawl. Just a little, you don’t need a lot. You will notice a fair difference. Some ratchets you’ll see a huge difference; my Taiwan Williams that I leave at work, it was like night and day.
I use oil on some ratchets like the SK thumb ratchet that I posted.
Just remember, anything with grease or oil needs to be recleaned every few years. Oil/grease, as much as it lubricates also collects dust or debris and, given enough time, can solidify.
That’s what the inside of my proto facom designs were like, grease was solid.
I took apart my Friend’s cheap ratchet last week and it was solid too, it’s almost like glue from a glue stick. The ratchet will work but you(KhariV) can imagine replacing your glue stick “lubricant” and replacing it with fresh lubricant, it makes a big difference. Jimbo’s ratchets were bought new from a distributor.
khariV wrote:
Honestly it’s really simple to put back together. The grease will help quite it down some and it be a bit smoother too. But I will be fine if you put the super lube on it.
khariV wrote:
If you weren’t the last person to use a ratchet, it’s worth opening it up.  Even if you just lent it to a friend, who knows what buckets of crud he dropped it in.  He might have even hosed it down to clean it up before returning it (don’t be that guy).  After a few times it doesn’t take more than a few seconds to pop a ratchet open and grease it.
Mondo1310 wrote:
It sounds like it’s not because how instructions read but it is easy. Literally, all it takes to reassemble is pushing the pawl down with your thumb and inserting the gear. That’s the hard part and it’s literally as easy as pushing the pawl down and inserting the gear. Put the O-ring back in the groove, then put the cover on and clip it down.
Instructions can be deceiving. The spring  tension on the ratchet itself is very manageable. Once you put it back together, putting the plate on is not a problem.  At least that was my experience with the ratchet.
Mission Accomplished!
I took it apart, wiped all of the existing oil out (there wasn’t much), added some new oil around the pawl and a blob of grease under the gear and got it all back together.  Best of all, it still works and there weren’t any spare parts!
One minor detail though, there was no O-ring, just the retaining ring and the plate.
Thanks again for all the advice.  I learned something new and wouldn’t have done it without the crew.
Are you sure it wasn’t stuck to the plate? Mine always stick to the plate and black on black with grease wasn’t easy to see. It should be pretty easy to find a replacement.
Absolutely certain.  I wiped down the plate back with a white shop rag, so if it was there, I would have seen it.  There was no o-ring.
What would I need to get to replace it?  I bought from the EBay link, so no one to go back to to say it was defective / missing a part.
Don’t worry, I’ve had some with and some without o-rings.  Doesn’t seem to change much.
You can probably find one on ebay for next to nothing. It’s not terribly necessary, but it is supposed to help seal the ratchet head…some say it doesn’t do a great job at that. Keep in mind that they build these with the mindset that someone is going to buy it, never open it and drop it in oil and dirt, then throw it in a box to store for the next day of dropping it in oil and dirty, etc..
