Milwaukee M12 Sub-Compact Screwdriver 2401-21 $69
CPO on eBay has the Milwaukee M12 2401-21 screwgun for $69 with free shipping, comes with a single 1.5 Ah battery and a charger. Tool is new and has full warranty.
http://www.ebay.com/itm/331693989884
Thanks for the post, adding to my addiction lol.
WOW good price too bad I already have one
I have the newer version of that driver, still a great tool probably my most used m12
Dano123Member since Feb 2016
Do you like that more than the impact or drill? I have never used one.
I like to differently it’s great for low torque situations but it can drive 2″ screws in pine no problem. It’s not as powerful as your impact or drill but it’s awesome for more finesse work, great little screw gun.
I considered buying one for my pocket screws, but I wasn’t sure if it was worth it.
You’ll use it more than you think
Edit: it’s great for assembly and disassembly
Thanks for the info. I will add that to my list
That’s impressive! I didn’t realize it had some power to it. Does the quick release hold 1″ bits or does it need the larger bits with the groove lock?
If this is the same as mine, as it looks to be, it doesn’t hold the 1″ bits, you will need the longer bits
HiltiWpgMember since Sep 2015
I use my Hilti 12v screw driver exclusively for panel work and trim outs.
I used the M12 fuel before that. The clutch makes trim and terminating cake and don’t ever worry about stripping and damage like you do with an impact. Impacts aren’t for finishing or finesse!
It needs to groove lock I stuck a 1inch bit in there and had to remove with the vampliers lol
Speaking of bits it’s been sometime which ones are you sticking with?
haha, another great use!
Still rotating, lost almost a month of time with my foot/ankle problems. Right now I have a Toptul bit which I don’t like as much as the Bluepoint(very similar bit styles). I haven’t even tried the PB Swiss bits yet.
The teeth though on them pliers will tear a bit to shreds though it’s pretty crazy how them teeth bite
What’s funny is some of the reviews claim the opposite…I think they’re just idiots or trolls because these things basically ruin anything they touch because they’re soo damn sharp and strong.
I’m afraid to use them sometimes kik
Yeah, if you don’t want to damage something you really have to have a light touch…almost wish they made one with the notch but with less sharp teeth. I know a couple of Japanese companies make them so I may give one of those a try, could be less sharp. I’ll let you know if it’s good enough for me to spend your money 😛
