Hmmm
Compact router
Rigid job max
Compressor
Not sure what I should buy first
router or compressor pending your needs, and cash, compressor comes with more costs than just the compressor, you’ll need hoses, fittings and don’t forget tools, nailers, nails…
Get the router.  The jobmax and compressor probably won’t solve any problems and just make you want more things to go with them.  Pick out the tools you really want to run on the jobmax or compressor and buy a normal cordless equivalent.
Router like jimbo said the air compressor will come with extra cost like the air tools and all the fittings and hoses
rrich1Member since Jun 2015
Depends on the jobs you are doing. If it is all diy, line up your jobs based on the tools you have or will need. Then buy accordingly. I’d does no good to buy a router if you are putting up new trim around the house.
