Air vents
jon burgessMember since Mar 2015
How to clean the dirt and grime off air vents. I have tried soap and water, soaking in simple green and green sponge and nothing work. My hand are big so it’s very hard for me to clean
Like the one in the pic. The ones a work are much bigger and wider
Sand paper and spray paint or just buy new ones if it is really bad
How fine of a sand paper
You don’t want any big scratches I would go with 120+
FazzmanMember since Apr 2014
gotta use a scrub brush or something bud. heck id toss it in a beadblast cabinet and then repaint it,if you had that option. Get zep purple cleaner,that stuff will eat off nearly anything,make sure you wear gloves its corrosive.
Fazzman wrote:
gotta use a scrub brush or something bud. heck id toss it in a beadblast cabinet and then repaint it,if you had that option. Get zep purple cleaner,that stuff will eat off nearly anything,make sure where gloves its corrosive.
Must be like purple power cleaner or superclean, careful how you breathe around those cleaners.
Or …. oven cleaner! That stuff will curl your nosehairs but man does it eat the dirt and grime off a lot of different surfaces. Spray it up in your bathtub, let it sit for 10 minutes then rinse off
Try the nylon brush for rotary tools.
That is a really good tip. Use that with a stiff scrub brush after letting it sit for at least 10 minutes. Or you can try and use a scotch brite pad. If that don’t work, then a trip to,the store for replacements. Good luck.
I am going to try zep purple cleaner. I do not have the say on where or not to buy new ones
Chud?
JerryNYMember since Jun 2015
I really like Tub O Towels for cleaning any greasy surface in the house.
Wonder Works Tub O Towels Heavy-Duty 10″ x 12″ Size Multi-Surface Cleaning Wipes, 90 Count Per Canister https://www.amazon.com/dp/B00022W4ZU/ref=cm_sw_r_cp_awd_KZBOwbEPTDXFF
They are very tough but thin enough and you can push them through the slats and pull back and forth. Also maybe you could unscrew the vent and put it in the dishwasher?
Yup, I vote for Purple Power! I buy the stuff by the gallon lol.  I use it to strip the chrome parts that come in my model kits, since it usually looks like crap.  The ol’ lady loves the stuff also, she uses it all the time.  Another thing that may work is “easy-off” oven cleaner.
