Following on from the video the guys have just posted on the Rigid CD-100 Combustible Gas detector.
What are your experiences with these kinds of detectors?
They work very well. Get to the general area with an electronic leak detector and then isolate with soap and bubbles.
I have not used the ridgid but have used the Bacharach, UEI, Extech, Accutools, Inficon and CPS.
I have used electronic leak detectors very often. Usually for refrigeration leak checks in grocery stores but they are used exactly the same.
I bought three battery model versions and the Kane was the only one that gave accurate readings for longer than a few weeks.
I just wanted to know if this is the case world wide that only certain ones seem to work very well.
Is this a uk tool, I’m not sure I’ve seen it before.
Yes it is Chad,
They also make my flue gas anyliser. 🙂
Thanks Wayne, u guys have all the fun stuff.
We need it, we are regulated to the max.
ive had a few, ive got a tpi currently which so far is working fine. but i dont use it very offten. My old regin was ok to but i broke the probe fiddling with it 🙁
which kane leak detector have you got? ive got the 455 fga but not the leak detector probe.
Hi Itchyspanner,
I also have the 455 but I got the full kit cost a few quid but it is a brilliant bit of kit as you know.
The sniffer just uses the battery of the unit. The other Kane sniffer that uses ordinary batteries is just as good. 🙂
