M12 Compact Vacuum
Santi_78342Member since Jul 2015
Just picked this sucker up (no pun intended) and am wondering if anyone else has one and how they like it?
Seems like a great little vac for quick clean ups, but I am also going to see how well it does vacuuming stuff out from under walls.
As a flooring guy, we usually just use a bench brush to accomplish this so we don’t have to lug around a shop vac + extension cord(s). But this thing coupled with a 4.0 battery should be able to handle I think.
On another note..this M12 stuff is addicting. I only recently bought into it with that sweet deal HD had on the M12 Fuel Rotary Hammer and have since picked up the Fuel screwdriver kit, hackzall, right angle drill, vac, & have ordered the caulk gun & Fuel hackzall.
I’m gonna need to order up some more L-Boxxes to store all this stuff!
yes the M12 line kinda grows on you……M18 is no different
HiltiWpgMember since Sep 2015
I have had it for awhile. I like it, but it needs a little more suction. It’s slightly underpowered.
dg1127Member since Jun 2015
Santi had mine for about a month no complaints here use is a lot more then I thought
I’ve got the Bosch. It’s okay. I use it to clean my work tables and saw table but anything larger than fine shavings it can not make the nozzle. Curious how this is compared. I like the size of the Bosch though.
Mr Holmes, is the Bosch powerful enough to use around the house for little messes? That’s the angle I am using with the wife. I mainly want it to clean saw dust off my saws and bench when I’m done. I thought it woukd be handy around the house too to get dust and junk out of tight corners.
I’ll pick one up if the price is right.
I often thought about one of these for the same purpose but I’m a little impatient when it comes to vacuums. I have my regular dust collection which does a pretty good job for the most part, and a small 3hp to pick up the stuff that don’t make it in the big one, never picks it all up……….
Well Mr Roundtree……meh. It’s not too bad but the nozzle only opens about a 1/3 of an inch and with the nozzle off its maybe 3/4″ and loses its focused suction. It’s great for what I use it for but because of the limitation to getting stuff into the machine I’m not sure it’s what you want. Truthfully, I love it. It picks up around the saw and on my work table really well for the little stuff. Larger chunks, meh.
I hope your still talking about the vacuum????
stainlessstroker95Member since Aug 2015
Yes I have one. And actually been putting it to use the past couple of days. It’s been picking up dust and small chunks. It does its job I would say. It’s not a shop vac obviously. I bought it for my wife cause she was fed up with the black and decker dust buster one. She really likes it.
rees332Member since Jun 2015
I got the m18 vac I think it’s brilliant
Petro0311Member since Oct 2015
I’ve been debating both the m12 and m18 for a while… I love my rigid shop vac but def need a small handy vac…
