Logging Trucks and Trains don’t mix…..
Seeing the truck on the crossing before hitting it with the train, the engineer hit the deck below the window level and the head end brakeman ducked down behind the wall and door under the middle windows, that leads down to the bathroom.
Both made it out alive. Anywhere there was glass, the pulp logs loaded cross wise on the truck, penetrated into the cab including through the number boards.
That is crazy. Where did this happen?
between
Winnipeg MB and Sioux Lookout ON
That is insane! Glad to here the guys made it out of the train. I hope the trucker had the same luck.
 apparently the truck driver was unscaved too……”What did you do today?” …………”oh nothing other than ducking from a few logs flying my way!”
Freakin wow!!
That’s flipping crazy
I bet there were some underpants that needed changed after that!
unrelated but back in 1979 was working in a saw mill installing a J-sorter and just before us on another line a 92″ stud 2×4 got jammed sideways and sprung out about 30 feet and hit a guy right in the thigh and sheared of the lower part of his leg……..wood is a very powerful thing when under force….
This is insane, what year is this from?
late 2014 I believe….
That’s pretty wild. I saw a similar result with a coal truck once.
The newer wide body locomotives are a lot safer than those old GP’s.
The craziest thing I’ve seen in a long time. We have a horse racing track in our fire district. They were receiving a load of gravel, while the truck was tipping it’s trailer, it fell on its side. The driver was on uneven ground. When the truck tipped on its side, the stack on the cab went through a window in he horse barn. The truck couldn’t have been in a better spot, the trailer missed the corner of the building and the stack was the only thing that damaged the building, just knocking out the window. If it would have been a foot forward or back ward it would have taken that structure out and knocked a large sprinkler pipe as well.
What was even more impressive was watching the tow company upright the rigs.
HiltiWpgMember since Sep 2015
Much, much older than that. Late 80’s early 90’s.
ya I seen that too, I dated it by the post I seen……….your right…….where are you from?
Winnipeg!
HiltiWpg wrote:
Winnipeg!
gotcha was just there in Oct should have hooked up…lol
