I found a Craftsman Professional 4 1/2 inch vise yesterday. This was a clearance item ($95) seems that Sears does not carry this vise anymore. Wondering if anyone has any experience with this vise? Should I keep this or get the 6 inch Harbor Freight for half the price?
Specs
Made with 60,000 PSI iron
4 1/2″
360 swivel
Weight (lbs.): 41
I think that at this price point none of the vise will be amazing. The Harbor Freight vice has some pretty horrible reviews. I think I might go with the C-man just because of that.
Looks like a pretty good vice at a decent price. I do have one of those HF vices that I got real cheap that has worked ok for the last couple of years of light use. I got it for 50 bucks and a similar one made by a better company was about 200.
you could easily spend 4 times that on a vise, having said that unless you need a pro model that price for that vise will do you fine…..I have pretty much the same vise and am happy with it…….
The Craftsman Professional vise is an imported copy of the Wilton Tradesman series. It’s a very good copy, so good in fact that I suspicion it may actually be sourced from Wilton.
It was probably the nicest Asian vise available and at that price it’s an absolute steal. Most Asian vises (HF vises included) employ a cheaper grey iron construction, but with 60K ductile, it will rival some of the higher end American vises in terms of resilience.
I wouldn’t let that one slip by me if I were you. Once you use a good vise, you’ll never have a shitty one again.
And as information, it looks identical to my $600 Wilton 1755 which is also 60k ductile.
A 4-1/2″ Wilton Tradesmen (albeit American made) will run you $400+
It’s more less Wilton and everyone else when it comes to Vice’s. Conductor is dead on, but have no experience with this one in question.
I have read good about the Craftsman but also read that a guy bent the jaws working on a driveshaft. He replaced it with a 6″ HF vise and it has held up better. Don’t know how true and makes me hesitate. I imagine the HF vise is a cheap grey iron construction. I assume 60K ductile is stronger? More or less brittle?
Ductile iron can be bent or twisted without fracturing while providing equivalent strength to steel.
Anything will break when used beyond its limit. Even they very highest quality tool manufacturers deal with warranty claims and breakage every day. Look around hard enough and you’ll find $1500+ Wilton machinists vises for sale that have been welded to repair cracks in the static jaw.
Don’t let one guys bad experience and probable misuse deter you. Those are good vises. Used and praised by one of the toughest vise critics I know.
And yes, ductile iron is much more resilient than grey iron for the purposes required of a vise. It’s more mailable allowing much better shock absorption and will flex where grey iron will crack.
If you tap a grey iron vise with a hammer and do the same with a ductile, you will notice more of a ping with the grey iron as opposed to a thud with the ductile. If the ductile vise is cast at 60k, figure the grey iron to be in the 30-40k range.
Thanks, You guys convinced me. I’m going to keep the Craftsman vise.
I think that’s a good decision!
This vise will replace a tilting Wilton vise on my basement workbench. I need a stronger vise in the basement. To really clamp something I have a real old blacksmith vise in my garage that I’m tired of walking the stairs to use. I’m about to build a woodworking bench for my basement workshop and I might to mount the Wilton on it so I can tilt it up or down below the woodworking bench surface. That was the plan until I saw this vise-less workbench today.
One can never have enough vices but this bench seems pretty neat. Just wack the holdfast and it’s clamped. My father had a wedge shaped wood clamp on his workbench that was fast and easy to use. Just put the piece to be clamped into the clamp then wack the wedge with a hammer then wack the other end to release it. This bench reminded me of that.
Funny this came up. I just bought a Wilton 1745 (4-1/2″). It was 445 at my local industrial supply. Got it mounted up today. I had been needing one and wanted one to last a lifetime. I was gonna get the mechanics style but wanted to stick to USA made.
Great pickup on the 1745. I have the 1755 and it’s one of my prized possessions. The imported Wilton’s are hit or miss. Some are pretty good vises, others not so much, but the Tradesman bullet vises are a cut above.
Thanks conductor. I’m sure the imported one would of been fine for me. Just wanted to splurge a little.
You’re opinion will change. Once you get used to that 1745 you’ll gag at the thought of a vise from HF or the like. They offer superior holding force and ease of operation that you just can’t get on a cheap vise.
FYI: There are huge metal chips inside the tube. I recommend taking it out, cleaning them out, and relubing. If you want to do that and need help with the tear down, just let me know.
Metal chip!? Why would they leave those in there? I will have to check that out. It came with a mounting templet/parts layout so I maybe able to get it apart. Il let you know what I come up with.
I couldn’t believe it either. I thought maybe it was just mine, but I’ve since found out it is a common thing.
You could probably use it forever without it ever causing an issue, but I couldn’t not clean it out.
I just spent the day using my new Craftsman clone of the 1745. It works sooo much better than the cheap (made in China) Wilton vise it replaced. It grabs onto the parts and holds while I beat and wrench on them. With the other vise I was constantly re tightening because the parts kept coming loose. With this vise I just snug the handle and the part stays put.
You’ll never buy a shitty vise again. The joy of tapping, drilling, or pounding on a part that doesn’t move is phenomenal. The homeowner “good enough for what I need” does out the window pretty quickly with a good vise.
