Sawzall Blades
So as I burnt through a couple blades today, as I was throwing them out, I got to thinking… Is there something I could do with these dulled out blades other than throw them at something. You guys trash them or does anybody do something creative with them?
What were you cutting that you burned through multiple blades in one day?
Tungsten carbide by Milwaukee, did some brick landscaping, but one was used then I decided to get rid of some old ones laying around.
I have an old one laying around to draw circles when I need one drawn..
That’s pretty good idea
You could always grind off all the teeth and sharpen it as a flat blade. You could also grind the teeth, debur the end and probably use it as a metal pry tool if you ever have to take apart any electronics.
HiltiWpgMember since Sep 2015
Throw em in a box, when you have enough, take to metal recycling.
jbw55Member since Jul 2015
Other than keeping a few for drawing circles as Comp mentioned above, I just toss the bad one’s……
I was thinking about that I have one of those handles you can put the blades in
I have a couple old blades ground down for cutting things like insulation, but they last so long you’ll still be looking for something to do with old blades.
What sawzall blade handle do you have, jimboslice?  I tried a friend’s milwaukee handle, but the connection to the blade is too loose for my taste.  If there was a better one even if it didn’t fold, I’d be replacing most of my hand saws with that.
 Its a craftsmen handle, came with a few blades, its pretty nice, everything fits pretty snug, it doesn’t fold either.
http://www.sears.com/craftsman-three-in-one-multi-blade-hand-saw/p-00936255000P?prdNo=32&blockNo=32&blockType=G32
I have a Milwaukee folding saw handle at the moment, but I’m not crazy about it’s size or that crappy rubber overmolding. I tried the recent version of the Lenox, and again, it’s too big and it broke pretty fast. My favorite was the all aluminum Lenox they were selling about 10 years ago. Can’t get them anymore 🙁
jeffmcmillan wrote:
That looks like a winner. Too bad it require a screw, but sometimes you have to compromise for a secure connection, and I’d rather that than vice grips.
The screw can be annoying, but how often are you going to change the blade? Worse comes to worse grab a couple of handles, I threw the blades out before I got the handle out of the package lol.
