I’m using my Skil worm drive saw to rip 5/8″ plywood and it’s leaving a rough cut.
What blade would you recommend for plywood?
Thanks,
John
How many teeth has your blade and what brand
I use a fine finish diablo blade and that works well enough. It could also be your depth set though. You’ll get the best results with the depth set to about an eighth inch deeper than the material.
The blade I have is an old 100 tooth and I’m sure it’s dull because the name is worn off of it. ^-^
I had the blade depth set to just a little more than the thickness of the material, so I don’t think that’s the problem. I will check out the diablo, I think I’ve seen them in Home Depot.
Thanks
Thanks
dull blades tend to heat up and usually tare more than cut. if you are ripping lots of plywood it’s best to get the right blade. if you have no option for a new blade run tape along the cut…..on both sides might help in a pinch….
Thanks
Is it one of those all steel blades designed (a long time ago) for plywood? Something like this?
Despite those blades being designed for plywood I think they’re one of the worst blades for it. I once saw one so dull that it was impossible to tell which way it should spin since both the marking and teeth were worn off.
I like the Diablo Ultra Finish. Great blade. Came stock on my new Magnesium Skilsaw. I have a couple of replacements too but they last a,long time.
Ooooooorrrrrr…….you could say “screw it” and get a Festool TS55REQ 😉
I’m thinking the cheaper option for him would be a new blade…..
Yes it looks like that, I’ve had the saw for a lot of years, just haven’t had a chance to use it much lately.
Yeah, I’m thinking a new blade is a better option…..
I will take a look at the Diablo Ultra Finish, that will most likely cure the problem.
Thanks
Comp….I am empowering this poor lad to make the big decisions. Geeeesez! I bet you don’t watch beer commercials!!!
