Milwaukee shockwave 2nd gen bits
DarynHMember since Feb 2015
Well let’s see how these compare to the 1st gen bits (which were garbage).
I’m gonna be heading to HD in a bit I might pick some of these up
Weird thing is that they are magnetic. It didn’t say that anywhere on the package either.
maybe that is the second gen part they are now magnetic garbage, truth be told I seldom use philips head generally always NO.2 Robertson (square) Canadian thing and the Milwaukee seems to last.
It’s nice that in Canada square drive took off. I have to say the past 15 years we have seen more drive styles take hold in the USA now. It used to be 95% Phillips and some slot drive for hardware. Now we have torx and all sorts now even at the big stores. The only thing that still is mostly Phillips is drywall screws still. I did not like the Milwaukee shockwave Phillips bits at all either. The tips got damaged pretty quick.
I use Robertson when I can but most common screws are Phillips sadly.
I went to dang HD it was packed!! I went to go scope out some Labor Day sales nothing special I was also hoping that HD was gonna have the new tough box with clear lid but nope! My wife just picked up a couple things for house and I totally forgot about the bits :/:/ oh well that means I gotta make another trip during the week
Keep us posted on how they hold up. I like the red touch on them.
suretyler97Member since Jul 2015
How much do they run
Most of electrical work can be done with a #1 and #2 square, I love it life has been much easier there still is a lot of Phillips stuff though. I can wire a whole panel with a #2 square ground bar, neutral bar, breakers and the cover but some of the higher amp breakers require a flat screwdriver.
Have you ever used the tamper proof screws in electrical work man I have and they suck because e the bits are so fragile
PROTOOLNUT wrote:
Fragile tamper proof screws. Gee, whats wrong with this picture? Its like when they made a padlock which people could break with a sledge, WTF? I want a lock so powerful you’d have to cut it with a cutting torch, in which case, I will know your there screwing around. And if the screws are supposed to be tamper proof, then build them like fort knox and be done with it. I swear, as technology gets better, other things get worse, human nature I guess.
They are strong it’s just the bits are expensive and wear out to fast that you use to put them in
What style of screws are you talking about?? I have a security screwdriver set that has all different types, I will post a pic tomorrow of it. Some are fragile and just plain stupid.
I’m not a Milwaukee fan and I know the first gen was horrible, but I never tried them for myself so I decided to give the second gen a shot. So it sheared in two pieces on the first screw which was a 3 1/2 inch deck screw which was 3/4 of the way in. It broke right where the red starts from the 1/4 hex side, I wish I would have taken a picture of it but I was pissed and threw it into the trees. I guess it was just a lemon but on the first screw damn.
That’s too bad.  I was really hoping Milwaukee would pull through with these after they had a chance to learn from the first generation.
This kit has a lot of different bits, I would say the fork type bits are the worst when it comes to removing screws.
I’ve been using these past couple days driving tapcons though furing strips into block and haven’t broken one yet. They are definitely better than the first gen but I need to use then more to get a good idea of what they can take. I’m just happy they don’t round over like the gen1. Also they fit the screw much more snug, reduces wobble. Remind me of the newest dewalt bits.
Which Dewalt bits are you referring too??
The max fit bits
DarynH wrote:
The max fit bits
Yea I love those bits, I have every length in the #2 Phillips
Man, those 1st gen shockwave bits sucked. I was soo disappointed, I knew they were going to be bad when the all arrived slightly bent. I haven’t tried the Dewalt bits but I love the Bosch ribbed phillips bits.
Update on how the new bits are holding up?
A lot better than the original version. Not perfect but I’m still happy
has anyone tried to heat a new one up and cooling it in oil just to see if it would be better?
JerryNYMember since Jun 2015
I needed a 6 inch Philips 2 and 3inch square drive bits so I figured I’d try the new Shockwave 2’s and they seen vastly improved. The new ones seem to have a rougher more durable oxide finish and don’t get chewed up so fast so they are definitely a huge improvement in my opinion. I haven’t used them enough to tell how they will hold up long term comparatively to other makes but they seem to pass the initial impression test well and at the very least they don’t seem like throwing your money away like the old shockwaves, although the first ones were so soft they seemed like they’d be good for stainless fasteners or softer metals as the bit would wear more than the screw head so they at least sacrificed themselves for a good cause…
According to Milwaukee they heat treat them for 12hrs vs 4hrs.
Isn’t that done in a flamed oven? The heat a quench introduces carbon(from the oil) into the metal…at least that is my understanding.
I’ve thought about doing this with bits/screwdrivers…but I’ve never done it and I’m not sure about how it fully effects the metal. I know it makes it harder but generally harder means more brittle…but I don’t know and haven’t done enough research to start doing it myself.
for something cheap like one of these bits it may be worth trying…….I find most strip or round off more than they snap….then again I use #2 Robertson mostly….
The thing is if I go through getting some oil and a container specifically for this, I’m going to use it for more than some bits. I need fuel for my torch also, might need a new torch because that thing hasn’t been used in a long time. I also have 11 different models, 9 different manufacter’s bits to use right now, haha.
