For some reason KWC, the video only opens to a general title page and not the video, on my iPad.
Try now
Wow, I’ve never seen anything like this.
That is pretty flippin cool!
who said screwing won’t change in the future?……
KWC wrote:
Try now
Thank you sir and leave it to Lamello! Awesome!
Pretty cool concept really.
Very cool!
Wow that is different than any thing I have seen. Neat idea.
Cool
That is really cool!
That’s really cool….I like it.
That’s pretty slick!
PROTOOLNUT wrote:
OK so let me get this straight. So you drill two different type of screws into each end, then you put the ends together, and use a drill magnet attachment to cause the screws your drilled in earlyer to tighten. If I understood that correctly, then yes I agree, screwing is the future. The idea here is that you can now put things together using what appears to be invisible screws, I assume if you wanted to remove them, you would just run the drill in reverse, correct? I guess we will see if this idea really takes on, keep in mind it has to past factory tests before factories convert to using this method on the assembly line.
True!
clearly a neat way to conceal fasteners especially for visible joints
I never thought I would say this about hidden fasteners…..wow.
