Hi guys
Is there any Gas Fitters / Plumbers out there that have purchased the above tool.
And if so what’s your honest opinions is it worth the $$$$ you pay for them
Cheers
Keith
South Australia
I’m not a plumber but did buy the copper cutter…just because I needed a tool fix.
It’s great in that you don’t need to turn a tubing cutter, but speedwise, IMO, it takes just as long on it.
Just mainly saves you on the wear and tear on your body….
The advantage I can see is in tight spots.
As well, just to how it *autofits*, there is a slight learning curve when putting the copper inside the tool so that it sits inside the *rails* as the circular cutter cuts. Hard to explain, but when you use it, you’ll know what I mean..
Yup, not s plumber here but I have an old house and lots of tight spots where a manual tubing cutters would have been a pain and I didn’t want to vibrate the pipe with a sawzall potentially disturbing old things and the M12 tubing cutter works great. It’s especially nice if using sharkbites because it leaves a nice smooth burr free edge. I’d echo what mobiledynamics wrote above that there is a small learning curve to acclimate to how the tool works. I’d just get a piece of copper and practice cutting a few cuts before making any critical cuts for real.
Thanks for your input guys, much appreciated [emoji106]
i had actually talked with the plumber i work with about that tool last week, they said its worth its weight in gold, for them they sweat houses every week so they are cutting a lot of copper and they all have one. its nice to just press the button and its cut. also the pvc cutter is great too!
