I just bough a used Metabo KHA24 battery SDS drill for £80, which has turned out to be faulty.
Before I bought it I did the usual pull the triger, and it run up fine, tried the second battery, that was fine to.
Then I needed to drill two small holes through a tile, as soon as the drill bit touched the tile – the drill stopped – a red warning light appeared on top of the drill, I have tried everything I know but can’t get it to work under load.
The armature and brushes are fine.
I took it to a tool repair shop, they wanted £280 to repair it, said the parts were £241.63 for three electronic parts in the drill – I can’t afford such repair prices, I took it back to where I bought it, they say hard luck – no gaurentee.
Question
is it possible to strip out the electronics and use it without them?
