Hey anyone have the feed rollers stop working but the planer knifes still spin. Was running 2.5 ” doug fir heard a loud pop and the piece just stopped feeding but the knives kept spinning. Brought it to dewalt $320 later they still can’t explain what happen. Anyone have an idea?
With the loud pop, I’m suspecting a gear. I can try to pull mine apart tomorrow and browse to see what I can find.
So after looking at the diagram (http://servicenet.dewalt.com/Products/GetDocument?docName=EA022468.tif&docPath=http%3A%2F%2Fdocuments.dewalt.com%2Fdocuments%2FEnglish%2FExploded%2520Art%2FEA022468.png&productId=22538&productType=7605&documentId=21151)
I’m thinking either a sprocket, #83, or the chain, #101. Also, check the speed selector lever. If it’s not fully engaged to 1 or 2, the rollers won’t spin.
Did you happen to change the speed while the planer was off?
That’s what I suspected as well I opened the cover and the sprockets were in tact I can manually spin one roller but the one is stuck
You shouldn’t be able to spin them freely. The chain is engaged on the sprocket to the drive motor. I’d investigate the one that spins freely. Is it the in feed or out feed roller that spins?
Thanks Ricky
Drive chain 115 goes from the gear box to the rear roller. Then, on the opposite side, chain 101 goes from the rear roller to the front roller. If one is spinning freely, it is most likely eith the chain, or one of the sprockets on the opposite side of the gear box…
Haven’t used my planer in a few weeks. Went outside to run a piece of wood through and the rollers weren’t spinning. It worked perfectly fine the last time I used it. Took it apart and sprocket and chains were in tact. What the hell is going on?
Be careful purchasing a new 735 type 2 which are manufactured in China. I have a type 1 which I have used for about 8 years now. I purchased the type 2 unused from a retired woodworker moving, and closing shop. The unit had a Shellix cutter installed, and was pristine with zero use. The first time I powered it up the motor smelled hot, when I ran a test board the motor started smoking, and repeatedly tripped the breaker. I pulled the motor, and had it tested at a professional electric motor shop. The field was bad, from the factory. No replacement parts are available for the model 2, and the model 1 used a different size armature and field, they are not interchangeable. I had to send the field to a rewinding shop in L.A. to be rewound. Beware of the Chinese manufactured model 2
I was planning a board and stop feeding and started smoking from the top right corner. The braker did not work and turned it off inmidiatly. I tried to start it the next day and nothing happen, i will not start. any ideas? It is a dewalt 15 amps
