M18 2606-22CT driver motor sparks?
FaldoeMember since Aug 2013
I just got the M18 1/2” driver set with the 1/4” impact driver. The model on the 1/2” driver box says “2606-22CT.”
I tried it our briefly and noticed there was a considerable about of sparking/arching behavior going on in the drill. A few times a small spark was emitted. Is this normal? I got the set new from International Tool. Thoughts?
The Impact driver seems to be more “normal:” minimal internal sparking.
It’s probably from the brushes wearing in.
Ahh, is that a common occurrence?
Yes it is. You will probably see the occasional spark too once they wear in also
yup its normal its happen to me b4 and u might even have a burning smell but don’t worry it goes away as long as it don’t smoke then u gotta problem.
Yup, all of my guns have done that till they wear in. If you hear any grinding or maybe if the machine bursts into flames you’ll have a problem though 😉
Migueld510Member since Jun 2015
Does this occur when you are engaging the trigger, or releasing it?  I am also thinking that it could be the electric brake in action, as from what I understand, it creats a lot of friction to immediatley stop the driver from spinning when the trigger is released.
pretty common even back in the day when you would put new brushes in some used tools
BremonMember since Dec 2014
Brushless tools spark as well and are not suitable to use around sources of ignition. The sparks are just more inconspicuous compared to brushed tools.
