Transportable tablesaw vs vacuum
Normally when I use my tablesaw indoor and outdoor I have vacuum connected but only with hose on the table.. Do you guys use vacuum on the blade protection as well?
I run my Midi on my DW 745.
But do have hose on top and on the table?
PeteWMember since Aug 2014
i dont. only time i would use it is is if i am inside a finished house and i can’t make my cuts outside.
Trim guyMember since Nov 2014
I use a Bosch table saw and I try to have the vacuum hose up to the dust port for every cut. Inside/outside/ or in the garage.
I never have the blade guard on as I tend to use a cross cut sled. Just the rear vac port.
Alan mMember since Dec 2014
I run the 50mm short festool boom arm hose  into a y  on the dc port on my dw745 . then a hose up to the guard
I only run both if it is a finished house.
the dw745 is very good at throwing the dust out the port . if im on a site or in a shed where dust isn’t a problem  I run the saw with no dust collector  but use the 50mm pipe into a bucket. I forgot to turn on the dc one time and filled the pipe up
