DIY metal vise
i really need a vise – does it qualify for me that i can buy a welder now?!
only fault I see is he should have made the hole for the handle and nut out of one piece of steel from a block (2 holes at 90 one of which would have been tapped to fit ready rod instead of welding nut as it will be trouble some the way he welded it……not any good to weld graded nuts unless you know exactly what nut you have …..a449, a325, a193, grade b7, f1554 grade, 105, a354 grades bc bd anf a490 among many others…..20″+ bar can snap 3/8″ of a weld with little to no effort…..twist that handle off as it can be brittle as glass…..
ScoszkoMember since Oct 2014
Nice idea. Not sure if I would trust it for heavy use. Like Comp said, there are some welds I would be hesitant to put under high torque.
there is a welder / welding experience talking out of you comp 😛
yup, may as well use tie wraps…..
