Anyone have a good laser level they recommend that is under 100 dollars? Im looking for something that can stick to the wall and be used to mark supports for trapeze racks for electrical conduits. I bought the Bosch GLL1P but it doesn’t have a way to stick to walls without setting a nail/anchor.
Thanks for the help in advance!
I can’t think of anything that mounts to the wall and can be easily repositioned..
My suggestion would be to look into the fastcap 3rd hand pole (5′ to 12′ height) and the fastcap 3rd hand lasermount. The pole gets adjusted from floor to ceiling and stays in place with pressure, then the laser mount allows any laser with a thread mount to be attached to it and slide anywhere vertically along the pole
the pole and mount should run you about $60.. I would think a self leveling line laser would be best for you because then you aren’t stuck to one point but can have a level horizontal line.
For under $100, something like this is about the best you’re gonna do:
http://mobile.walmart.com/ip/4246048?wmlspartner=wlpa&selectedSellerId=10&adid=22222222228016892076&wl0=&wl1=g&wl2=m&wl3=42531634592&wl4=&wl5=pla&wl6=58402050774&veh=sem
Maybe this ones.. Price 44-73$ on Amazon
