Tap & Die…. Case?
I broke down and bought the DeWalt Tap & Die sets a few weeks ago. I’ve used them a few times and they’re not much different than any other. The problem I see in the not so distant future is storage. I Carefully cut open the plastic so I could reuse them but I need a better solution. Nicely laid out and organized. Any ideas?
I didn’t even know Dewalt made tap and die sets. Hrmm, The only thing i can think of is a small case that drill bits come in and foam with cut outs for all the pieces. That’s the only solution I see as being practical its kinda crappy that Dewalt didn’t ship it with a case.
Was not aware they made one either
Home Depot carries them. They have three small sets. A small & large SAE and a small Metric.
Trim guyMember since Nov 2014
I have 2 sets of the small sizes and yes the tools themselves work fine. But storage is definitely an issue.
It’s a tough one…. I’ve found empty cases online but not sure of sizes they accommodate or if it will fit all the pieces I have.
FazzmanMember since Apr 2014
They make tap indexes similar to drill indexes. They can usually found at Enco for like $12.
They wont hold your dies unfortunately
snohikerMember since Mar 2015
yea I saw them as well and the fact they didn’t have a case is the reason there still on the shelf at HD I now ide loose them
Don’t go putting those new taps into foam. You won’t ruin them but you will be picking out foam bits from the sharp edges constantly. I know that y’all have a collection of tools, including routers. You could make a wooden case pretty easily. The machine shop that I used to work in used individual tool cases that were then nestled into foam. I prefer Kaizen foam and the DeWalt Tough System DS150 to keep moisture away from those bare steel tools.
Make or buy a box and get some Kaizen foam from  a company called “fastcap” they have great videos showing how to do it. That way you custom make it to exactly what you need. And have fun doing it too. Good luck.
