Ring on bandsaw table.
So just wondering, I did major oops and left a paint can on my bandsaw table. The paint did not leak or anything, I just left a large ring on the table,like a water mark. Just wondering what’s the best way to fix this, and also should I be using some sort of oil on the table.
lets see a pic….
WD-40
1000 and/or 2000 grit wet sand paper,
wax remover ( to clean the surface from the WD-40)
cabinet makers wax – to seal the surface
or you can also use vinegar and 500 grit paper ( I read that but not sure how it works out )
Thanks guys I’ll try that. When I get a chance, I’ll add a photo
I know it doesn’t look like much, but it drivese nuts.
That doesn’t look to bad. Its not hard to clean it man
Yeah I already hit with some sandpaper. That’s the last little bit just does not want to come up.
Duns221Member since Dec 2014
try gasoline, or if you have some kerosene they both work but i would take your saw outside before you try
