Good day folks.
I recently had to replace the slider in my BJR182. I have it in place and am now struggling with the chuck.
According to assembly diagrams I have seen online, I believe I have all the pieces in the right order and positions. However, I cannot seem to get the driving sleeve to slide over the guide sleeve far enough to match up with the driving sleeve guide and sleeve. I am aware of the notches on the guide and sleeve for the bump outs in the driving sleeve. I also understand the the ramped portion of the driving sleeve in regards to putting pressure on the shoulder pin and compression spring. I just, for the life of me, can’t get the the driving sleeve to cooperate with e the guide and sleeve.
Anyone run into this difficulty?
I had a similar issue once because the chuck bolt wasn’t screwed down all the way.
Hello, try to put spring number 15 to another side (not like in assembly diagram) and I think you will be good 🙂
