Has anyone actually used these markers? I usually buy the standard sharpies at HD for $.68 a piece but these new Milwaukee ones are advertised to work a little bit better for construction purposes. I use them daily for marking anchor points on walls, marking conduit for bends, and marking stuff to be cut.
http://www.homedepot.com/p/Milwaukee-Inkzall-Black-Fine-Point-Bulk-Marker-48-22-3100/204813511
[External image (www.homedepot.com), not copied]
Just got one…yet to use it…hopefully it works on oily services….
It is nice..Javier has a review on it on his YouTube page “tool crazy”.personally I find it is very similar to the sharpie pro other then the fact that the Milwaukee has a hard hat clip.
I like it because it will stand out more since it is red instead of gray.
Thanks Tyler and RedSionach.
The inkzall aced all the tests on the laminate- dusty wet and oily surface. The sharpie pro did the best on a ceramic tile and wet tile cutting. Although the inkzall isn’t more durable than a normal sharpie. The sharpie pro is the king in the durability department. For some reason the sharpie pro did the worst out of the wet and oily test in the laminate. On plastic the only one that had their ink not smear immediately was the sharpie pro.
I have been using the sharpie pro since your review (very well done by the way) and very satisfied, the yellow rubber molding really makes a difference when it comes to grip…. but the clip breaks very easy. After a few weeks I think I will try the inkzall in hopes it holds up better.
Tyler, did your sharpie pro have the same issue as mine where the white sleeve inside the cap came loose? Just curious, other than that the sharpie pro is a very good marker
Javier, I’ve had that exact same problem quite a few times with the sharpie pro. Pretty annoying when you only have one hand free and that happens.
Yes Javier, that had been a problem with the pro I’ve experienced.
