dc012 radio problem
rudagar2001Member since May 2013
i have a dc012 type 1 radio. i’m having charging problems. i’ll charge it before i go to work and it will have the steady light saying it’s charged, and then it dies after an hour or two. so i’ll plug it in and it says it’s charged again after just 10 or 15 minutes. and then it will die again after another hour or so. i just bought new batteries for it, so i know that’s not the problem. is the internal charger messed up? or could it be something else
Try charging the batteries on a normal charger. If you have different results then you know it’s the radio. Otherwise it could be the batteries.
