what causes hammer action
woolyheadMember since Apr 2013
Looking inside the drill on the net doesn’t explain what causes the hammer action or how it’s turned on and off. Can anyone tell me, please?
tooljoeMember since Jun 2011
From what I understand, your average hammerdrill/driver drill use a type of marry-go-round hammering. Where the top of the merry-go-round is the chuck and the mechanical toy model horses that go up and down are attached to chuck. i.e. every time a horse goes up, the chuck is pushed up…that energy is transferred to the bit and from the bit to the material.
here a pic i found on the webs hammer drill/driver…
[External image (2.bp.blogspot.com), not copied]
On SDS drills, I believe it does not work this way…i could be wrong though, but I believe is more of a piston action hit.. that goes up and down. Think of a piston in a car rotated by the crank.
here is a pics a found on the webs SDS drill..
[External image (www.its.co.uk), not copied]
[External image (www.freepatentsonline.com), not copied]
A marry-go-round action, although while doing thousands of blows a minute, is is not as direct of an impact as a piston moving up and down.
kjonesMember since Oct 2010
Tool joe is pretty much right.  A “hammer drill” or percussion hammer is essentially two ribbed “gears” hitting against each other (one stationary, the other spinning and connected to the bit)., whereas an sds+ or sds max rotary hammer uses an actual beat piece (heavy piece of metal pushed forward to interact with the bit). An sds+ bit is pneumaticly pushed by the beat piece being driven forward by the piston driven off of the motor, and an sds max hammer is driven by a beat piece actually striking the bit. The sds+ and max hammers function in a very similar manner, while the percussion style is completely different.
