I recently purchased an older used DW059 (has base for ni-cad I’m using xrp lithium). Worked OK then was down on power. Took it apart and found it needed a brush and the fan shroud was broken. Replaced those two parts, seems to work. My last impact was a 20v Craftsman Pro and it was badass. This thing is pretty sad. It has trouble with car lug nuts. Is this just how they are or is mine messed up? Any way to test it?
If the brushes were worn out, you probably have a worn out motor as well. I would recommend getting a GRC service. It should have plenty of power when running healthy.
The wire in the one brush was loose. I tried to solder it in but just made it worse. The actual brush surface looked good. So I don’t think it is to worn out. How could I go about testing it?
May be the piece which has been purchased is not of good quality . So the defects are arising.
