Cutting Stone
MBermudezMember since Feb 2013
Is it possible to cut through solid concrete block (4″x8″x12″) with the DW 745? If the answer relies on a specific blade, please tell me the type of blade required.
I’ve never seen anyone try and cut concrete with a table saw. I don’t think it would be able too. Plus the max depth of cut on that saw is 3-1/8″, it wouldn’t cut the full 4″.
PKDEWALTMember since Jan 2012
If the blocks aren’t really hard and you only need to make a few cuts, I would use a circular saw with a diamond blade i have done it before it works decent or you could get a diamond blade for a grinder and make one pass and flip it over and make another pass.
Thanks, Gatorb888.
Although I purchased the 745 for cutting / ripping wood, I asked about the possibility of cutting through manufactured block because I think I noticed a blade for the 745 that is the 10″ version of a 4″ blade I have on a hand-held mini-saw.
The 3 1/8″ limitation is easy to work with: I can simply flip the block and finish the cut. Since the block will only be used for outdoor applications, imperfect cuts are fine.
My concern is with two issues. First, would the saw have enough power to get through the block? Second, would the dust from cutting block / pavers / brick be especially damaging to the saw?
MBermudez
PKDEWALT:
Thanks, also, for your post. I’m doing quite a bit of outdoor landscaping, including much work with blocks and pavers, so I’ll likely splurge and get a saw designed for cutting through such material.
Will you be cutting curved edges like in this video:
A table saw wouldn’t be able to do that, especially safely.
If it’s just straight cuts you’ll be doing I would get a 14″ chop saw with a masonry abrasive wheel. Curved cuts, you may have to go with a grinder + cutting wheel like in the video, or a circ saw like MBERMUDEZ said.
The table saw does have a 15 amp motor and just about the same RPM as a 14″ chop saw but I just don’t know if will have the power, like you mentioned. It may be able to do it but probably isn’t great for the saw and may be a little dangerous. Plus the fact that the concrete would ruin the base of your table saw when sliding it.
EDIT: Also, unlike this guy in the video above don’t wear socks and sandals when grinding please.
Here is how the pros do it:
https://www.youtube.com/watch?v=UnDKY-JRrD8
