DC759 vs DCD760
DSMember since Jan 2013
  I’m new to this so I hope that I do it correctly. I own both a DeWalt DC759 and a DeWalt DCD760. I have a total of 8 DC9096 batteries that will function in either unit. I plan to selling one of the drill/drivers and keep the other. The problem is that I don’t know which one I should keep since the available specifications on the units are pretty sketchy. It seems that the DC759 is a 1st generation but I can’t seem to find what generation the DCD760 is. Can someone tell me what the actual differences are between the two drill/drivers and is there a definite advantage of one over the other?
kjonesMember since Oct 2010
The 760 is the current iteration of 18v compact drills. It has the frameless motor (better), better transmission, lighter weight, etc.
StevenMember since Nov 2009
I own several of each, since i do construction.  They are BOTH good compact 18-volt drills.  I wouldnt sell either one.  But, if i had to choose one model to keep it would be the DCD760.  The DCD760 is a more modern version of the DC759; newer, lighter, shorter & has a light.  The DC759 came with Ni-Cads & the DCD760 came with Li-Ions.
