DC390B Saw Work with DW9099 Batteries?
mhorwitz57Member since Oct 2012
Just wanting to make sure they are compatible before I buy the bare saw.  Any drawbacks?
kjonesMember since Oct 2010
That is the compact battery, so essentially has a lot less gas in the tank. It will run the saw, but the saw will drink that battery very quickly. 18 volts is 18 volts, so the power will be the same/nearly the same, your run time per charge will just be very short. Hope that helps.
