12v Max driver torque numbers needed
mixedgasdiverMember since Jan 2012
Greetings,
I just picked up a 12v Max kit and am curious about the torque settings on the DCS6102 1/4″ screwdriver. Does anyone know of a chart so I could then relate the numbers on the dial on the front, to inch pounds or foot pounds of torque?
Thanks for the info.
kanxrusMember since Jan 2009
I am not aware of any such chart? I’m not sure it would do you any good. There are way to many variables to consider when driving a fastener, for a torque setting to have any value.  Size of the fastener, type of material the fastener is going in, the accuracy of the clutch itself, the speed at which you drive the fastener, etc….
What are you doing that you would need these numbers?
Hmmm… I see what you’re saying about the type of fastener, material, etc. I was hoping that the clutch would be accurate enough to have some numbers associated with it.
I do a lot of work on motorcycles, it’s not a full time gig, but I at least make play and vacation money this way. All the fasteners on bikes (just like cars) have a torque spec. Traditionally I use a torque wrench and a torque screwdriver with bits that I can change out. For bigger jobs I’ll use my air tools, but most jobs are not this big and I don’t like listening to the compressor or fighting with the hose for small jobs. After finding out how great and easy to use these tools were, I thought I could use the driver for reassembly of parts.
I’ll keep hunting and let everyone know if I find something. I have emailed DeWalt, but not gotten anything back yet.
tooljoeMember since Jun 2011
here an idea, how about using the torque wrench on a bolt first then use the drill settings to sort of calibrate… I do that on things… I tighten up a screw by hand then set my drill to the lowest number and go up until it stops clicking… that works for me.
edit: 🙂 brain fog.
quig1984Member since Jan 2012
if you got the kit you prob got the impact driver to I’m guessing? Its will deliver 79ftlbs. I’m guessing read that given that ur asking about the screwdriver
