I was going to modify the Dewalt DW9116 Charger to allow me to charge other vendors batteries.
When I opened it up, I discovered it is not isolated by a transformer from the line. This makes it unsafe to add any externally accessible connector.
**Do not even think of modifying it in this way, as there could be severe shock hazard if connections are brought outside**
I took a few pictures and added some notes as others may find it interesting. (I am an Engineer)
The charger seems to use a custom control IC, marked with what may be a B&D part number (starts with BD).
For old batteries with no internal temperature sensor the charger uses a temperature sensor thermally coupled to one of power connector pins. As the battery heats up at end of charge (or if hot from use) the controller senses the conducted heat from battery via the connector pin which is welded directly to last cell in battery.
For newer batteries, they have an internal Negative coefficient Thermistor, brought out on a third pin on the connector. This is a much better method as it is better coupled thermally to cells, but adds a small cost to each battery.
[External image (dewaltownersgroup.com), not copied]
Very good observation ;D
The new 20v max chargers are totally different
thanks, I was wondering why there is a 3rd pin in my battery packs.
Oops…I just added to output lines for other charging to a DW9310 charger-soldered to neg and pos. Wires are insulated and contacts are also isolated-ill add pics. Let me know how dangerous this is or can wiring be modified to add transformer (maybe DC9310 has transformer?…too lazy to tear apart and snap pic just yet).
Thanks
[External image (img840.imageshack.us), not copied]
Uploaded with ImageShack.us[External image (img822.imageshack.us), not copied]
Took a look inside the DW9310 charger…looks like transformer is in there. Here is pic.
[External image (img843.imageshack.us), not copied]
Hi Tim H.
Having rebuilt a nicad battery pack and managed to cock it up good and properly, I have also managed to fry what appears to be a diode within the charger. It referenced as D26 to the RH side of the “Buck Regulator” it appears to be blue with some coloured bands on it. Can you tell me what it is please and its associated value.
Kind regards
Chris
Chris,
That is a resistor not a diode.
It is R26 not D26.
Search on web for resistor color code and you can figure out the resistor value, from the colored bands. It looks like at least a 1/4 w resistor.
I don’t have a large picture anymore and it is difficult to see the colors in the small picture I posted.
The gold band at the end means 5% tolerance.
It looks like it has 5 color band .
If the colors are orange-black-green-brown-gold then it likely is a 3050 Ohm resistor 5% 1/4W
T
Did anyone on this post ever figure out what the pinout is on the BD2003XR3 chip?
Al
