Different location for the LED light in cordless drills…
tooljoeMember since Jun 2011
That location would eliminate the shadow.
[External image (oi54.tinypic.com), not copied]
kjonesMember since Oct 2010
Try one of the drills with the light located there.  They simply do not work well.
kanxrusMember since Jan 2009
Case in point.
[External image (dewaltownersgroup.com), not copied]
I was not aware there are some out there… the light over the trigger does not work well for me either… i’m thinking of hacking mine 🙂
Case in point.
How hard would it be for the dewalt engineers/designers to come up with something like this…
[External image (oi56.tinypic.com), not copied]
[External image (oi53.tinypic.com), not copied]
I used cheap lights (non-LED) here to see how it would look. with todays tecjnology, there are very tiny LED light (smaller than the ones on the pic) that emit a lot of light. also, the drill collar only would get a little fat to house the LEDs.
Dewalt did a similar thing to the new 20v max impact driver. There are to many moving parts on a drill/driver to put 3 lights up front. I doubt you will ever see it on a drill driver.
I was not aware of that, though I own the 12v max impact driver and love the 3 LED lights.
they are not very good engineers/designers then 🙂 because I can think of two designs that could work.
Well I would personally enjoy a drill that had 3 lights. I see companies viewing light’s as a secondary feature, and won’t go out of there way to design a drill around lights.
FelipeStalveyMember since Apr 2012
Led Light Accessories LED Controllers LED Power Supplies
what do you say?
