How to improve radio reception on the DeWALT DC011
Glenn LeverMember since Aug 2011
I am looking for ideas on how to improve the reception on the DC010 on weak radio stations.
The tracks I race at have small FM radio station they us in conjuction with PA systems to announce staging times.
I was thinking of mounting a CB antenna next to the radio and running a wire to the orginial antenna mount on the DC010.
Any suggestions?
kanxrusMember since Jan 2009
You could get some speaker wire, hook it into your antenna connection point on the radio, then run the wires up higher on your trailer. You get a boost of signal the higher you go with it. Or you could buy a FM RF Amplifier board.
Isn’t the CB band a very small segment of the FM band?
That is why I thought of using a CB antenna. I could get some real hieghth with that.
The wire rapped in a CB antenna is a function of the wave length (1/4, 1/2, 3/4, 1/1 wave length which is 102 inches).
Do you know the wire length rapped in the antenna on the radio?
I used to play with CB radio’s before cell phones were around. I even built my own antenna out of conduit pipe and mounted it on my roof. That was a long time ago, and I’ve forgotten most of what I learned then.
I don’t know the length of wire in the DC011 radio antenna. Try out the CB antenna, I don’t see what it would hurt? Just tune the radio into a weak radio station and give it a try? If it doesn’t give you a boost I would try making your own Dipole antenna out of braided speaker wire?
I could make a tuned dipole out of 300 ohm tv antenna wire 96 inches long which is a half wave length of FM, but how would I connect it? for a tuned antenna you need two poles????
