Questions from a newbie
aalupattiMember since Jun 2011
My first post.
I am planning to buy some tools for home use. I have some questions
1. Are the drill bits intercompatible between various makers like Dewalt, Black and decker and so on.
2. I am planning to get this drill bit set. Is that sufficient enough for a normal home user. ( I live in an apartment and do very basic stuff) . http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=110663252225&hlp=false
3. Is there any other better kit of drill bits. I am not in a position to spend huge amts of money
4. Can an impact driver be used also as a screw driver .
this is the one i am looking at http://www.amazon.com/Bare-Tool-DEWALT-DC825B-18-Volt-Cordless/dp/B002RT7K4Q/ref=sr_1_2?m=ATVPDKIKX0DER&s=hi&ie=UTF8&qid=1307035593&sr=1-2
5. This does not have a battery . will it come with a power cord
Thanks.
kanxrusMember since Jan 2009
aalupatti wrote:
My first post.
Thank you for posting!
Yes all drill bit’s are interchangeable across brands. Some bit’s can be larger and will require a larger sized chuck. Typical home-owner brands offer 3/8″ chucks, and some offer 1/2″ chucks. All professional 18v brands offer a 1/2″ chuck.
This kit would be sufficient for 90% of tasks around the home. The bit’s however only go as high as 1/2″ so any larger sized holes would require you to purchase larger sized bit’s individually.
You’ve done a good job hunting around. This would be a good kit to start out with, then as your needs grow your bit’s can grow with it. It looks like there is extra room inside the case to store other bits. Other’s on this site may disagree and offer you some additional choices based on their opinion, and experience.
Yes, you can use the impact as a drill. It’s not alway’s the best option, but it will get the job done.
This is considered a “bare” tool. It was designed to lower the cost of a replacement/addition for someone who has invested in combo kit, or a single tool kit. The DC825B will come with no batteries, charger. It is considered a cordless tool, and cannot be used with a cord.
Thank you so much for a detailed, fast and understanding reply. ( Most of the forum, newbies are killed with nasty replies)
Just one more question.
– Is it better to buy a drill with a cord as it saves a lot on battery purchase ?
Thanks
Are you referring to this forum? I don’t think most of our new members get beat up, unless that new member starts talking smack about yellow, then the gloves are off! ;D
It depends entirely on your personal needs. That’s a decision you will have to make on your own. Here are some of my thoughts.
Corded Pros;
Limitless runtime
Typically cheaper
Lighter Weight
Depending on what you buy, corded can have more Power/Torque.
Corded Cons;
Not Portable
Most professional drills lack a clutch
Cordless Pro’s
Portable
Has a Clutch
Has 2-3 gear settings
Cordless Con’s
Costly
Upkeep costs when batteries wear out
Downtime associated with charging
Limited Runtime
thanks once again
