DEWALT Launches Industry’s First Diamond Edge Chop Saw Blade DW8500
kanxrusMember since Jan 2009
DEWALT® Launches Industry’s First Diamond Edge™ Chop Saw Blade that Allows Diamond to be used to cut Metal
TOWSON, Md.
(Nov. 9, 2010) – Today, DEWALT announces the launch of the industry’s first Diamond Edge Chop Saw Blade (DW8500). By utilizing technology that allows diamond to be used to cut metal without sacrificing cutting performance, the Diamond Edge blade reduces product costs for the end user and lasts 100 times longer compared to conventional DEWALT abrasive blades, DW8001 and DW8003.
“At DEWALT, we are pioneers in developing power tools and accessories that deliver industry-first innovation and technology that leads to increased productivity and performance,†explained Brad Nohr, product manager, DEWALT. “Our new Diamond Edge Chop Saw blades are just one example of how we are leading the industry with product development that addresses end user concerns and raises the bar to exceed contractors’ expectations.â€
Ideal for tradesmen tasked with cutting pipe, steel studs, angle iron, rebar and threaded rod using a chop saw, the Diamond Edge blade makes use of advanced brazing technology and premium diamond grit for increased speed and longer life compared to standard DEWALT blades. While the brazing technology is what enables the blades to cut metal with the speed of a conventional abrasive wheel, the premium diamond grit lasts more than 100 times the life of standard DEWALT abrasive blades in metal.
A steel blade core provides the constant cutting depth, capacity and stability of a solid core, and the exposed diamond matrix allows the blades to cut concrete, plastic, fiberglass, rubber, non-ferrous metals, stainless and ferrous metals without loading for flexibility on the jobsite.
The Diamond Edge blade will be sold at independent distributors. The Diamond Chop Saw Blade will be available in December 2010. Expected to retail for approximately $249, the product will come with a 90-day money-back guarantee.
About DEWALT;
DEWALT is a leading manufacturer of industrial power tools and accessories with more than 300 power tool and equipment products, as well as 1,000 power tool accessories, including corded and cordless drills, saws, hammers, grinders, routers, planers, plate joiners, sanders, lasers, generators, compressors, nailers, saw blades, metal and masonry drill bits, abrasives, screw-driving accessories and more. DEWALT tools can be found nationally and internationally, wherever tools are sold. With more than 1,000 factory-owned and authorized locations, DEWALT has one of the most extensive service and repair networks in North America. For more information, call 1-800-433-9258 or follow DEWALT on Facebook and Twitter.
Summary;
DEWALT announces the launch of the industry’s first Diamond Edge Chop Saw Blade (DW8500). By utilizing technology that allows diamond to be used to cut metal without sacrificing cutting performance, the Diamond Edge blade reduces product costs for the end user and lasts up to 100 times longer than standard D EWALT blades.
