hi I’m hoping someone can help me here when using DW938 recip saw it recently has not been sounding right it makes sort of a grinding noise has anyone else had this problem? and i also have a problem with the keyless blade change any help would be appreciated
Could you be a little more specific as to where the noise is coming from?
What is your question related to the key less blade change?
the sound is coming from the gears possibly i believe I’m not 100% sure and i have figured out the blade problem thanks though
Sounds like the gears have worn down. Here is a link that may be of some help.
