When are they going to release the full size vac?
jcopelloMember since Nov 2009
when are they going to release the full size vac? and is it really going to be $600?
kanxrusMember since Jan 2009
They are already available. There are 2 models;
[External image (images.grainger.com), not copied]
D27905;
Type          Variable Speed /Tool Activation
Tank Size 10 gal.
Tank (Gal.) 10
Amps AC         11
Amps @ 120V 11
Voltage         120
Hz                 60
Static Pressure (In.) 114
CFM 103
Tank Orifice (In.) 1 1/2″
Tank Type Plastic
Hose Dimensions 1 1/4″ x 15 ft.
Length (In.) 19
Width (In.) 14
Height (In.) 23 1/2
Filter         Nano Coated Pleated
Replacement Filter Paper Media Filter Bag
Power Cord Length  20′
Net Weight (Lb.)      25
Retail – $400+
D27904;
Type          Variable Speed With Auto Filter Clean & Tool Activation
Tank Size 12 gal.
Tank (Gal.) 12
Amps AC         11
Amps @ 120V 11
Voltage         120
Hz                 60
CFM                 103
Tank Type Plastic
Length (In.) 19
Width (In.) 14
Height (In.) 29
Net Weight (Lb.)      29
Retail – $600+
framerMember since Jan 2011
how about a vacuum that is strong, but somewhat compact, maybe even square shape so that it doesnt take up a bunch of space in a truck or van.  with some kind of integration to hold the hose and attachments.  something to compete with the shopvacs.
j booherMember since Mar 2011
Anyone know the db rating on these vacuums?
kjonesMember since Oct 2010
I don’t know the db ratings of these, but they are miscategorized when called simply “shop vacs”, as they are dust collection units.  These certainly can be used as shop vacs, but they are designed to much higher than a standard shop vac, as they are made for dust collection in shops, clean rooms, hospital remodels, etc.
72 dBA
