Ryobi Lawn Mower Issue
FillMember since Jun 2024
May have posted this in the wrong thread.
sorry!
lawn mower keeps stopping when I left it to turn positions. Not battery, not heat related. It does this even when I’m on the patio with no grass so it’s not struggle to do anything. Any ideas?
Your not the first person to have this issue so I am wondering if a certain model has been having issues.  I have not seen a fix or what is causing it.
hdogMember since Aug 2025
I’ve had a similar issue.  After mowing for a while, the mower would shut off while mowing.  I found that the extended handles were slipping down.  The lock disengaged.  I firmly pulled the handles to fully extended and the mower started.  There must be some interlock internally.  I tried to zip tie around the handle to keep it from moving, but they did not hold.  I may try drilling a small hole and put a screw in to keep the handles fully extended.  Don’t know if this could be your problem.
