Looking for a 5″ (125mm) dia wire wheel for bench grinder with 1/2″ (12.7 or 13mm) bore
Preferably stainless steel, if not steel or brass and not a cheaply made Far East product. I cannot find anything in this size.
I bought a couple from Amazon that were both stainless and brass.  MIne had an arbor on it thought.  It was a 4″
The ones I have found as 5″ have larger bore and i will need to use reducer which I don’t like.
I found one in Amazon Japan from a brand called SK11, SK11 is a OK’ish brand.
It seems the model number is 344505
Hole diameter is 12.7mm and thickness 14mm.
Looks quite well made in this photo.
