A LOOK INSIDE DEWALT’S DC9180 XRP LITHIUM ION BATTERY.
******************************* UPDATED 3.29.2011 ***************************************
Updated.
ah ha……finally got the ones with the sony cells uh
Yup…. I have a feeling they’ve been out awhile.
But what is the pros and cons about this change? Is it only going to be sony cells now or will it be from both sony and a123? Is there any different capacity? Dewalt talked so much about how good and superior the a123 cells where compared to other cell manufactures but now they have sony instead? What to belive?
Both Sony and A123 use a lithium phosphate chemistry, and both are very good batteries. I won’t speculate on the reasons for the switch, but the Sony cells are proven with their use in the compact lithium since their launch, so I am not worried about it.
I think Sony in general has been a proved to be a viable battery for the PT industry as a whole. Makita and Hilti have been using them for awhile, however both have been using the oxide version of Sony batteries.
I have 4 of these 18V batteries. I also have 4 of the yellow chargers. I just bought these batteries (new), but are stamped as 2010. I left the batteries in the chargers for 2 days straight. Then pulled all 4 of them to get the voltage with a high quality digital meter. They all read 19.9V exactly. I do realize they were fresh off the charger & not under a load.
Without opening the packs, how would I know if mine has the Sony or A123 cells inside?
Maybe the packs with ‘NANO’ on the side has the A123 cells & the newer packs with ‘XRP’ is the Sony?
The labels with “Nano” are mainly A123 cells, the “XRP” are either both and the only way to tell is the part number on the battery and the serial number
I noticed there is 3 posts. +, -, & the middle one is?
Middle is a thermistor in NiCd/NiMH batteries. In li-ion, it’s some sort of signal pin, I haven’t looked at it but I assume it’s either a serial bus or an open collector output that tells the charger if the battery is hot/cold/full/empty/unbalanced/shorted/overdischarged.
I have taken apart 20 or so of these packs over the following dated periods. Late 2007 through mid to late 2010 have A123 packs. It looks like the latter part of 2010…. the change was made to Sony Iron Phosphate. I have opened packs up as late as September 2010 that still have A-123 packs. A fair assumption based on my findings would be, anything 2010-40 or earlier would be a safe bet to find A-123 cells.
Looks like the last 10 months have been switched to Sony. Again, these are just my assumptions based on what I’ve taken apart.
I have a 18v drill with a lithium ion battery…can I use it with the new cordless brad nailer that asks for xrp battery, because I have two new batteries and the nailer comes with none.
Yep…..absolutely.
maybe it can sound stupid …but can i change the subc batteries inside my 18v pack to li-ion ones to imprrove performance
Yes, 54V will be pretty powerful I imagine, but longevity will be approximately zero.
So there are 12 cells in the battery pack? (12 x SE US18650FT)
With two serially-connected packs of 6 cells connected together in parallel, doesn’t that mean its 2.2Ah?
The UK version DE9180 is listed at 2.0Ah
http://service.dewalt.co.uk/Products/PartDetail.aspx?PartID=81075&BOMRegionID=1
and the smaller UK version DE9181 is listed at 1.1Ah
http://service.dewalt.co.uk/Products/PartDetail.aspx?PartID=90218&BOMRegionID=1
Why by accurate with the 1.1 and not with the 2.0 (2.2)?
Confusing
Hello
I am very intrested in swapping my 18V NiCad battery internals, some XRP NiCad, some NiMH with the same internals from the older 18V NANO Phosphate and using them with my DC9310 charger and Dewalt 18v tools . Is that possible? Any tutorials on how? Any advice?
