HOW TO REMOVE THE ROHM SUPRA SK CHUCK!
kanxrusMember since Jan 2009
HERE ARE A FEW SIMPLE STEPS ON HOW TO PROPERLY REMOVE THE ROHM SUPRA SK CHUCK. THESE STEPS SHOULD WORK FOR MOST  DEWALT HAMMERDRILL MODELS.
http://www.youtube.com/watch?v=UEj8qv02o9Q#noexternalembed#
IamVinceMember since Jun 2009
Thanks …now I know how to fix my broken drill.
klmathewsMember since Aug 2010
the video no longer seems to be available. Can it be viewed somewhere else?
I can see it…works on my end? If you still can’t see it, it’s on Youtube. Just keyword ‘How to remove Rohm Supra.
cirialMember since Aug 2011
New here.. Needed to replace my chuck on the DCD950 and this video is invaluable.  How much loctite do I use (on all threads, just at the bottom..), and should I get the red or blue loctite?
Also, if I dont have a mallet when hitting the allen wrench, would a hammer be just as fine?
A hammer would work fine, just don’t put a lot of force behind it. Use the red loctite, and apply a lite coat on the first few  threads.
jconradhMember since Sep 2011
Quick question:
I have read the Rohm chuck should never be opened or closed by using the drill itself, rather only hand-tighten the chuck with the spindle locked.  Is this true?  I never had a problem with my DC927 chuck until I lent my drill to a friend and he used the drill motor to tighten the chuck onto a bit.  Afterwards the chuck would lose it’s grip if I tried to free a stuck bit in reverse.  Never had that issue prior.  Now I have bought a 700 Jacobs chuck to replace the old Rohm, and I won’t lend out my $300 drill again.
Thanks,
Jeff
kjonesMember since Oct 2010
jconradh wrote:
Quick question:
Thanks,
Jeff
I have never heard of using the motor to open or close the chuck being a problem.  I will not go so far as to say what is the proper way to use it, but I always (as in EVERY time) use the motor to tighten or loosen my chuck.
I have several Dewalt cordless drill that all have the Rohm plunger chuck, and I always us the motor to tighten and loosen the chuck. Where did you hear this from?
From the DC927 owners manual:
“Self-Tightening Chuck Operation (Fig. 5–7)
WARNING: Do not attempt to tighten drill bits (or any other accessory) by gripping the front
part of the chuck and turning the tool on. Damage to the chuck and personal injury may result.
Always lock off trigger switch when changing acces sories.
WARNING: Always ensure the bit is secure before starting the tool. A loose bit may eject
from tool causing possible personal injury.”
p.s. The new Jacobs 700 series chuck works fine.  When it fails I may try the Rohm again.
Jeff
HA! Well I guess we all learned something today! That being said, I probably won’t follow those instructions  ;D
Dewaltdude.. so I had applied loctite and installed the Rohm chuck on my DCD950 back when I asked a couple questions in this thread.  Fast forward to yesterday at work, I’m using it to try to take out a 4 inch phillips head screw that is in a concrete wall.  I put my drill on drill mode, highest clutch setting on gear 1.
The screw didnt move, I stripped it a little bit and then after a quick second my chuck fell off! 🙁
What am I doing wrong here?  I just redid the installation last night and applied a very liberal amount of loctite this time.  Used a hammer and wacked the allen key real good.
What kind of loctite did you use? I used the LOCTITE THREADLOCKER RED 271.
I got this stuff at Discount auto parts..  Permatex Threadlocker Red.
Wonder if it’s just crappy. I put it on the last few threads closest to the inside of the threaded spindle the first time I installed the chuck.
This time I put significantly more on the threads so I will see what happens.
Bottom line it should never come off no matter how torqued a screw is in right?
Correct, it should never come off. Make sure the loctite has a few hours to set before you touch it. I let mine rest inside the house where it was warm for 24hrs just to be safe.
tooljoeMember since Jun 2011
my suggestion is to grind a little off the tip of the screw… my guess would be that the screw is a hair too long and not allowing it to tighten down… that or add a washer, with a big enough hole for the screw and small enough to fit in the chuck… IMO.
EDIT: i just noticed that this chuck does not have a screw to lock it in.
@tooljoe, thanks for the suggestion but this is the stock chuck for the DCD950.
@dewaltdude, I let the thread locker dry the first time I installed it for a few days. However at that time just applied a small amount on the base of the spindle where the chuck attaches. Used the drill only a handful of times before it fell off trying to extract a rather stubborn screw from concrete. Now that I’ve applied a rather liberal amount of thread locker red to the threads and it’s dried for several days I may go back and see if I can get that screw out without it falling off again…
What a headache!
giavraMember since Nov 2011
kjones wrote:
Quick question:
Thanks,
Jeff
Yes it does exist in some manufactures key less chuck ,Metabo chuck does this to prevent the chuck from destroy it and you must then open the key less chuck removing the safety clutch behind the chuck and loose the chuck.
theaceMember since Dec 2012
the video says it is locked or expried, can anyone upload or explain again?
