BOSCH LAUNCHES NEW LITHEON IMPACT DRIVER!
kanxrusMember since Jan 2009
[External image (mdm.boschwebservices.com), not copied]
Features:
High Performance Motor and All Metal Gears Deliver 2,800 RPM/3,200 BPM
Designed Hammer and Anvil System Produces 1,500 in.-lbs. (125 ft.-lbs.) of Dynamic Torque
Most Compact Impactorâ„¢ Design – For increased maneuverability in tight spaces and extended comfort
Built-In LED Light – Great for dark corners or enclosed areas
Spring-Loaded Impact Mechanism – Reduces user fatigue
1/4″ hex drive with Quick Release
Optional Gear Box Cover — For Added Protection
Externally accessible brushes — For easy brush replacement
Variable-speed trigger — For complete control
Includes:
(2) — 18V Litheonâ„¢ FatPack Batteries – BAT618
(1) — 30-minute Litheonâ„¢ Battery Charger – BC630
(1)–Double-ended Phillips Bit
(1) – Belt Clip
(1) — Carrying Case
Specs:
Drive: 1/4″ Hex
Impact Rate: 0-3,200
Length: 5.7″
No Load RPM: 0-2,800
Torque (in. lbs.): 1,500
Voltage: 18V
Weight (lbs.): 3.8
qadsanMember since Feb 2009
Based on the specs, this is going to be the tool to beat for its size.  I just wonder how well it will perform in real world comparisons.  My Milwaukee 2650 impact driver has 70 in lbs more torque and 500 more impacts per minute than my DeWALT DC827, but my DC827 walks all over my 2650 in terms of providing more real world sustained torque and getting my jobs done faster.  I do like the feel of my 2650 better and it feels like a solid unit, but it’s quite heavy compared to the lighter weight DC827.
Competition is good and helps raise the bar another notch higher.  I look forward to trying Bosch’s new Litheon Impact Driver someday.
erngumMember since Aug 2012
The 18v Litheon 4pc combo is down to $409 from $498 at Lowes.  Just picked one up yesterday.  Been saving up for this kit (i.e. hiding money from the wife :-\).
Ern
I’m really curious to see how well the impact performs. If you get a chance, post up some info on it.
