Milwaukee M12 jig saw or hackzall
aviMember since Dec 2013
Hi
I’m looking into a cordless saw for multi-purpose use. Obviously they are meant for different uses but as an all around tool which would you go with?
What will you be using them for?
JavierMember since Aug 2013
For me, I would go with the hackzall as its great at cutting a variety of materials and its portability is great. It can get in more places than a jigsaw would but at the cost of precision. But it all really depends on what you will be using them more for. If you need something to cut details and shapes go for the jigsaw.
Another suggestion might be a multitool as its great for plunge cuts and as added benefits can do much more than cutting such as sanding and scraping. Try cutting the bottom of door jambs for flooring with a reciprocation saw or jigsaw and you will see why a multitool is so great. But the downfall of multitools is the blades are expensive and slow at cutting. I wouldn’t use a multi tool to cut 2×4’s
Like I said, it all really depends on what you will be using them for and even then, each one of these tools is not a do it all solution.
Javier did an awesome job explaining the pro’s and con’s on each. I really wish I could pick one over the other I think the Hackzall might win out but not by much.
+1 for the hackzall, but it is in dire need of a fuel update!
Fuel Snob! 😆
But seriously, the M12 Jig is an awesome little machine. I got it the week it came out and can’t say enough good things about it.
I don’t have the Hackzall, but I can tell you that during my home remodel I said at least 10 times that I wish I did.
As others have said, it’s all about your intended use. If you do more woodworking I’d suggest the jig, but otherwise the Hackzall is a lot more versatile.
I have both the M12 jig saw and the hackzall. They are both great tools. I would say I reach for the hackzall far more though.
BababooeyHTJMember since May 2013
You’re comparing apples to oranges. I use my hackzall for tons of things. Its a great little tool and with the scroll blades that a lot of people sell it can do a lot of things that you would normally do with a jigsaw.
Don’t get me wrong for certain things like round cuts a jigsaw is the way to go. The hackzall is a great all around tool.
