D28715 Chop Saw
couchmusicianMember since Mar 2021
I just purchased this saw and after performing numerous cuts on a section of 1 inch square tuning, I cannot get a straight cut. The cut is always at an angle. The blade walks to the right on every cut regardless of how much pressure I use.  The factory blade is thin so I purchased a thicker one but still get the same result. Also the holding clamp is not perpendicular to the piece when clamped, regardless of how tight I clamp it. I did make several cuts on a larger piece of material and still get the same results.
