Drill choice
IOWAJC85Member since Oct 2020
I have a drill and hammer drill. Looking into getting a impact driver but not sure if I could just use hammer drill and impact driver for putting in screws or if I should still use all 3. Any help would be great.
Welcome to the forum.
My hammer drill may be toggled to normal drilling, so I use that single tool for both types of drilling operations. My drill has been retired to be a spare tool on my boat.
The impact driver tool is used for fastener insertion removal.
In my case, two tools are required, not three.
Der_DachsMember since Oct 2020
You typically would only use the hammer function when drilling into brick or concrete, not when driving screws.  I would say that if you have a drill and a hammer drill, you probably don’t really need an impact driver unless you just want something that is faster.
Sorry, I must disagree, the impact driver is the best tool for driving / removing fasteners. The impact driver is very effective, causing the least damage to the head, providing the best results, as compared to using a drill or using hand tools.
True but do you absolutely need it?  I work in an auto plant where I use a Milwaukee M12 (non Fuel) drill driver all day long.  At home, I have a DeWalt Xtreme 12v screw driver (non impact) and other than the Milwaukee being faster, Ive seen little to no difference in how they perform.  Is the Milwakee faster?  Sure but I don’t see myself replacing the DeWalt until either both batteries fail or the drill itself fails.
